18 years agoRGMII with the triple speed ethernet MAC core
Hello, I have a board with a Stratix II 180 C3 FPGA and a Marvell gigabit Ethernet PHY. The MDIO connection with the Phy works well. I can get the Phy status/id/etc. I also receive Ethernet pac...
16 years ago --- Quote Start --- hi, I remember that there is register in the MARVELL PHY to control the RGMII receive/transmit timing. You can try to see them. regards, --- Quote End --- Hello, I did not found the detailed datasheet for the MARVELL PHY device, can you send it to me. Thanks
