18 years agoRGMII with the triple speed ethernet MAC core
Hello, I have a board with a Stratix II 180 C3 FPGA and a Marvell gigabit Ethernet PHY. The MDIO connection with the Phy works well. I can get the Phy status/id/etc. I also receive Ethernet pac...
16 years agoI'm using the Altera Triple Speed Ethernet IP with cyclone iii, and trying to test the Rx and Tx of 10/100/1000 Ethernet MAC(RGMII). The test is done as following:
1- setting the loop_ENA bit in command_config register to 1 and 2-comparing the statistics counters aFramesTransmittedOK and aFramesReceivedOK to verify that the transmit and receive frame counts are equal. 3-checking the statistics counters ifInErrors and ifOutErrors to determine the number of packets transmitted and received with errors. According to the attached file named"Triple Speed Ethernet User Guide" So, kindly send me a design example made using the SOPC Builder to perform the internal MAC local loopback on it. Thanks
