18 years agoRGMII with the triple speed ethernet MAC core
Hello, I have a board with a Stratix II 180 C3 FPGA and a Marvell gigabit Ethernet PHY. The MDIO connection with the Phy works well. I can get the Phy status/id/etc. I also receive Ethernet pac...
16 years agoHello liangbowen, as i see, i also work with TSE and marvell PHY.
Now i have workable transmit part from nios to PC, but i have some problems with receiving of packet. So i can help you with transmit and you can help me with receive. My configuration is: Q 8.1 SP1 nios II 8.1 TSE Marvell 88e1111 I send packets from nios through the MAC level and i want to receive it the same way from the PC. At first it would be great to now how you made the receive of packet? i try to make it by alt_avalon_sgdma_register_callback which will be launched after the packet came to PHY->MAC. But i can't make it to step into the isr function in debug mode, i don't know what is the problem... So i'll answer all your questions.
