14 years agoRGMII interface on custom board
Hello everyone, I'm trying to get the web server example design up and running on my custom board. I'm using the Micrel KSZ9021RL which has an RGMII interface. I've gotten to the point where ...
13 years agoYes, I used those examples. I had to modify this file to point to my TSE, SGDMA, descriptor memory etc. It seems to talk to the TSE just fine to control it, I just don't have any packets coming out of the TSE to the phy. I see packets coming from the network through the phy to the TSE, just not out of the TSE.
My output looks pretty much like Scott's did, only it sees the phy at [6] like it should from the jumpers, it is 1000Mbs(as it should) . It can also sense correctly the 10/100/1000 speed interface that the phy negotiates on it's own as I change network speed(different routers). Since it doesn't have [packets going out, DHCP doesn't work, neither does a static IP though.
