14 years agoRGMII interface on custom board
Hello everyone, I'm trying to get the web server example design up and running on my custom board. I'm using the Micrel KSZ9021RL which has an RGMII interface. I've gotten to the point where ...
13 years agoStart Eclipse, create a new project from example projects and choose either web server (RGMII) or simple socket server (RGMII) example. It will create a new project and there will be a file called "tse_my_system.c". Copy it to Your project directory.
Or You can create a new .c file and add the same contents to it:
/* REQUIRED ONLY IF NETWORK IS RGMII */
# ifdef ALT_INICHE
# include "ipport.h"# endif
# include "system.h"# include "altera_avalon_tse.h"# include "altera_avalon_tse_system_info.h"
alt_tse_system_info tse_mac_device = {
TSE_SYSTEM_EXT_MEM_NO_SHARED_FIFO(TSE_MAC, 0, SGDMA_TX, SGDMA_RX, TSE_PHY_AUTO_ADDRESS, &marvell_cfg_rgmii, DESCRIPTOR_MEMORY)
Then remember to edit this file and add your initialization stuff instead of Marvell structure.
