14 years agoRGMII interface on custom board
Hello everyone, I'm trying to get the web server example design up and running on my custom board. I'm using the Micrel KSZ9021RL which has an RGMII interface. I've gotten to the point where ...
14 years agoDo You get any timing violations then? Is it only transmit path isn't working? If yes, then be sure You've constrained ALL the clocks properly. I had similar issues, when rx worked, but tx not.
