14 years agoRGMII interface on custom board
Hello everyone, I'm trying to get the web server example design up and running on my custom board. I'm using the Micrel KSZ9021RL which has an RGMII interface. I've gotten to the point where ...
14 years agoHi Socrates,
Thank you for your reply. I took a closer look at the data sheet and it does say that valid PHY address are in the range on 1-7. I changed the resistor configuration and it is now at address 0x01 but it still appears to perform the same way, the console says it's running but I see nothing on the RGMII lines or in Wireshark. The MDIO interface seems to work perfectly. I'll keep at it. Thanks again, Scott
