Remote System Upgrade for ARRIA 10 FPGA Devices over UART with the Nios II Processor
- 5 years ago
After you update the rpd file, do you performed reconfiguration or power cycle the board to see if the new image is being configured into the FPGA?
The reason is that the rpd file update is only updating the flash content and not reconfigure the FPGA
@BoonBengT_Altera @JohnT_Intel @Deshi_Intel @n_scott_pearson
flash upgraded completely .
1. after upgrading it is not giving expected result, it means after upgrading led should glow. if load .sof of same project lead will glow.but if load .rpd file led is not glowing.
upgrading is taking more than 3 hours(Uart baudrate value is 115200)
- APPU_appu5 years ago
Thanks @JohnT_Intel
yes I powered off and turned on but there is no output.- JohnT_Altera5 years ago
May I know if you generate big endian or little endian format of rpd file? Have you try the other format? Have you verify the contain of the flash to be correct?
Hi @JohnT_Intel
little endian of .rdp file
