17 years ago
relation between resync_clk and mem_clk in DDR2
Can anyone please tell me the phase relation between resync_clk and mem_clk in DDR2.
1 Reply
    So you must be using the standard DDR2 core and not the high performance DDR2 core. I believe you have to manually specify the phase for the resync clock.
    The resync_clk is used as an interim capture clock between the DQS strobe and the mem_clk domain. The ideal phase depends on clock frequency as well as timing delays between the memory and FPGA. Ideally (providing maximum setup time between clock domains), it falls exactly at the midpoint between the DQS strobe and the 2nd mem_clk edge following the DQS strobe.
                             ____      ____
    DQS         ----________|    |____|    |____|-----
                            ^----^DQS latch
                  ____      ____      ____      ____
    resync_clk  _|    |____|    |____|    |____|    |_
                                     ^resync latch
                ____      ____      ____      ____
    mem_clk         |____|    |____|    |____|    |____
                                             ^mem_clk latch
    Jake
