17 years agoReg AN427 Example Design on Quartus 9 WE
I like ur input reg VIP example design: AN427 on cycloneIII EP3C120 I tried to synthesize and create programming file instead of the provided sof file. But the Analysis & Synthesis result repo...
17 years agoThe first two warnings are assigned to particular RAM instances in your design. Check, why these instances apparently have settings, that are incompatible with Cyclone III. A warning doesn't prevent synthesis, so may simply ignore it.
The two errors are causes by your FPGA device options settings. You must specify the configuration pins as regular I/O after configuration.
