17 years agoReg AN427 Example Design on Quartus 9 WE
I like ur input reg VIP example design: AN427 on cycloneIII EP3C120 I tried to synthesize and create programming file instead of the provided sof file. But the Analysis & Synthesis result repo...
17 years agoOk. I tried creating a similar design with same settings & synthesised after assigning pins. When running Analysis & Synthesis i got warnings:
Warning: Assertion warning: Ignoring parameter INDATA_ACLR_A that uses input register with clear signal -- RAM block for device family Cyclone III of altsyncram megafunction cannot use input registers with clear signals Warning: Assertion warning: Ignoring parameter WRCONTROL_ACLR_A that uses input register with clear signal -- RAM block for device family Cyclone III of altsyncram megafunction cannot use input registers with clear signals And while running I/O Assignment Analysis, i get errors: Error: Can't place multiple pins assigned to pin location Pin_F4 (IOPAD_X0_Y65_N21) Info: Pin BITEC_DVI_IO_OUT_DVI_ISEL is assigned to pin location Pin_F4 (IOPAD_X0_Y65_N21) Info: Pin ~ALTERA_ASDO_DATA1~ is assigned to pin location Pin_F4 (IOPAD_X0_Y65_N21) Error: Can't place multiple pins assigned to pin location Pin_E2 (IOPAD_X0_Y61_N14) Info: Pin BITEC_DVI_IO_OUT_DVI_DAT is assigned to pin location Pin_E2 (IOPAD_X0_Y61_N14) Info: Pin ~ALTERA_FLASH_nCE_nCSO~ is assigned to pin location Pin_E2 (IOPAD_X0_Y61_N14) Please help me.
