Reference design F tile PHY IP
I have created the example design for Display port Tx only using Quartus prime pro 24.1 in that F tile Phy IP version showing version mismtach as the design using 4.4 and the tool having version 4.8. At this stage i couldnt find the PHY configuration used for that example design.
- VenT_Altera
Hi @number_7,
Thanks for reaching out.
Allow me some time to investigate your issue. I shall come back to you with the findings.
Ven
*Kindly note that 15 July 2024 is a national public holiday. Please expect a delay in response.
- VenT_Altera
Hi @number_7,
What is the device and its OPN?
Could you please share the .ip file from which you generated the Example Design and describe the steps to replicate the issue?
Ven
- VenT_Altera
Hi @number_7,
Thank you for attaching the files.
Yes, I'm seeing version 4.4.0 in the F-Tile PMA/FEC Direct PHY IP as well, in the Example Design generated using QPP v24.1.
Upon checking the F-Tile PMA/FEC Direct PHY IP in the Example Design generated with using QPP v24.2, it uses the latest version, v4.9.0. Therefore, you may generate the Example Design using the latest QPP v24.2.
Ven
- VenT_Altera
Hi @number_7,
Yes, QPP v24.2 is the latest and newly released version. It is recommended to use the newer version of the software.
With that, do you have further inquiries in this thread?
Ven
- number_7
- VenT_Altera
Hi @number_7,
Thank you for confirming.
I’m glad that your question has been addressed. I now transition this thread to community support. If you have a new question, please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed or response within the next 15 days to allow me to continue to support you. After 15 days, this thread will transition to community support. The community users will be able to help you with your follow-up questions.
Ven
