number_7
2 years agoReference design F tile PHY IP
I have created the example design for Display port Tx only using Quartus prime pro 24.1 in that F tile Phy IP version showing version mismtach as the design using 4.4 and the tool having version 4.8....
VenT_Altera
2 years agoHi @number_7,
Thank you for attaching the files.
Yes, I'm seeing version 4.4.0 in the F-Tile PMA/FEC Direct PHY IP as well, in the Example Design generated using QPP v24.1.
Upon checking the F-Tile PMA/FEC Direct PHY IP in the Example Design generated with using QPP v24.2, it uses the latest version, v4.9.0. Therefore, you may generate the Example Design using the latest QPP v24.2.
Ven
