12 years agoReed Solomon IPcore 13.0 problem
Hello, I'm trying to use the evaluation version of the RS encoder and decoder. I configured it as (223,255) with 8bit symbols and cascaded them, generating the control signals with the following ...
12 years agoYou are still not doing it right. your counter goes from 1 to 223, that is ok but then it becomes 1 and sop of second packet is generated without check on back pressure.
You better run your counter freely on valid from 0 to 254 starting 0 at start of valid. You need to stop your input data and valid at counts 223~255. that way you don't need to use back pressure. your sop will be at count 0 & valid while your eop will be at count 222 & vaild.
