shanti's avatar
shanti
8 months ago
Reconfigure Agilex-7 with PCI IP causes system reboot
Hi
We have a PCI with Alteras Agilex-7 eval board connected to a Intel Sierra Forest server running Ubunto 24,  when reconfigure our Agilex-7 eval board the PC reboots often which causes alot of frustation since we are not alone on the PC server.
  1. what is the proper procedure when needing to configure with a PCI IP, how to issue a re-enumeration?
  2. What is the procedure when needing to reconfigure a design that has a PCI IP
  • Wincent_Altera's avatar
    Wincent_Altera
    May I know which eval board that you are using ?
    Because for Agilex 7 , we do have F-series and I-series.
    BUT if procedure to configure the PCIe, you may refer to the guide under
    https://community.altera.com/discussions/ip-and-transceiver/how-to-run-pcie-gen-5-design-example-using-altera-fpga-device/125814
    there is a document .pdf who mentioned the full setup that connected to the host.
    That can be a good kickstart for you.
    Wincent_Altera
  • shanti's avatar
    shanti
    The board is mounted in a Intel server and runs Ubuntu 24.04.3 LTS (GNU/Linux 6.6.65-060665-generic
    Wincent_Altera
    Hi ,
    Let me know if there is anything else I can better assist.
    Wincent_Altera
    • shanti's avatar
      shanti
      Hi Wincent
      I still cant find anything that explains what the procedure is when we have a new configuration file that we like to configure the Agilex with without causing a crash or reboot. The document says reboot!!
        Wincent_Altera
        Hi Shanti,
        What do you means new configuration ? Is it new .sof file to configure the pcie ?
        All PCIe need to go through reboot for re-enumeration process, so reboot is mandatory for the PCIe to link up. (This is based on PCI-SIG specification standard)
        Wincent
