14 years agoreceiving trs problem in hd_sdi
am having problem while receiving trs from the receiver side .while transmitting am sending the packets in correct formate as "fffff" "00000" "00000" "xyz" " data " and then spacing of tx_trs is also...
14 years agoAs mentioned, difficult to see what you want, but in your picture your signal tx_sdi_rx signal (or similar name, can't remember) is "U" which without further information looks like it would be your rx input pin, so you've not got anything connected to it!
