14 years agoreceiving trs problem in hd_sdi
am having problem while receiving trs from the receiver side .while transmitting am sending the packets in correct formate as "fffff" "00000" "00000" "xyz" " data " and then spacing of tx_trs is also correct . so please clarify it . please see the attachment for the sequence .
Form a CLEAR and REASONABLE question if You want to ask something. It's hard to find out what do You need.
As mentioned, difficult to see what you want, but in your picture your signal tx_sdi_rx signal (or similar name, can't remember) is "U" which without further information looks like it would be your rx input pin, so you've not got anything connected to it!
