14 years agoReceive Transceiver clock recovery problem without loopback
Hi, I am working on a high speed optical fiber link between two FPGAs. Now the design seems to work perfectly in a loopback setting. But when I connect two boards together, download the ex...
14 years ago --- Quote Start --- Thanks for your help, I really appreciate it! --- Quote End --- You're welcome. --- Quote Start --- Today I played around with the altgx and altgx_reconfig megafunctions, trying to reconfigure them with different parameters etc... nothing worked. --- Quote End --- They do work. I've used them to test the eyeQ registers in a receiver, and test the VOD control in a transmitter. Start with the simulation models and Modelsim, and once you can read registers there, move onto hardware. --- Quote Start --- I only have sketchy cables around, I will have to buy new ones. When looking at the clk2_p clock with the scope I don't see any meaningful signal (only something that looks like noise), so the cables probably don't do the job... --- Quote End --- Did you check at the source of clk2_p and make sure there is a signal there first? It might not be your cables, though you should buy some good quality ones. --- Quote Start --- I will also implement a "clock measuring logic" as you suggested, maybe it will show some obvious problem, like very different clock frequencies. The way I did this in previous designs is simply by incrementing a counter at every clock cycle of the clock I want to measure, and then look at a SignalTap waveform sampled at the 50MHz clock, and do some math... I hope I can get it to work soon... I'll let you know how these things go. --- Quote End --- Great. Feel free to ask more questions. Cheers, Dave
