14 years agoReceive Transceiver clock recovery problem without loopback
Hi, I am working on a high speed optical fiber link between two FPGAs. Now the design seems to work perfectly in a loopback setting. But when I connect two boards together, download the ex...
14 years agoYes, this is the board I am working with.
>> However, none of the REFCLK signals from the transceivers route via the HSMC connector What do you mean? I think that clk2_p/n (figure 2.3 in the manual) is the clock that the design sees as the pair hsmb_clk_in_p2 and hsmb_clk_in_n2, which is then used as a refclk further in the code by the CDR (the code is available on the website too). What I did now is that I connected clk2_p/n (figure 2.3) from one board into the SMA_clk_p/n of the second board, such that the clk2_p/n of the second board is the same as the one from the first board. I am not sure if the mux that is pictured would create problems though (like adding a delay to the other clock), It doesn't work though... with this configuration there is no data sent/received by the second board. Either my connections are not what they should be, or the cables I am using aren't doing the job.
