13 years ago"Real-Imag to Complex" in DSPBuilder Advanced Blockset
Hi, I want to know how to obtain a Complex Number from Real and Imaginary inputs. And also the other way round, i.e., if I have a Complex Number, then how to obtain it's Real and Imaginary par...
13 years agoThe answer to this is version dependent. In 12.1 and before, you can simply use the simulink "Complex to Real-Imag" and "Real-Imag to Complex" blocks. They will simulate and synthesize just fine in the Advanced Blockset. In 13.0, these blocks are in the Advanced Blockset, and should be use as the simulink blocks will cause errors.
