12 years agoReading external data using On-chip FIFO and NIOS II
Hi all, I'm trying to read a 8-bit ADC with parallel output using NIOS II. I need to read the ADC at 24MHz to capture correct samples. I have been trying a 1K On-Chip FIFO to capture this data....
12 years agoAre you able to poll the CSR registers and see that data is being pushed onto the FIFO correctly?
