16 years agoRead request to PCIe testbench Root port BFM
Hi, I am using the PCIe megacore function testbench to verify my PCIe end point design. I have replaced the Altera end point design with my end point, which has a DMA. I have also replaced the ...
15 years agojust browsing and this post caught my eye. it's been a while since i've used this core but i seem to remember that there was a bit that needs to be set in a configuration register that allows the endpoint to initiate a transaction - think it was "bus master" or something like that. I know you say in your original post that the DMA is master, but have you explicitly set the required bit....just a thought !
Johnnyman
