Ash_R_Intel
2 months agoHi,
Please follow the guideline in the L- and H-Tile Transceiver PHY User Guide: https://docs.altera.com/r/docs/683621/current/l-and-h-tile-transceiver-phy-user-guide/pma-bonding
As I understand you need PMA only bonding of the channels. For this, you will need only one ATX pll clock to be driving all the channels.
Another important consideration you have to make, is the channel placements. As you need max 20G, you will need to use the GXT channels.
Hope this helps.
Ash_R_Intel
2 months agoYes, you understood it right.
As 20G can be achieved only by GXT channels and for the clocking at that speed ATX pll is the preferred choice. Refer section 3.1 PLLs of the same document.
