Please follow the guideline in the L- and H-Tile Transceiver PHY User Guide: https://docs.altera.com/r/docs/683621/current/l-and-h-tile-transceiver-phy-user-guide/pma-bonding
As I understand you need PMA only bonding of the channels. For this, you will need only one ATX pll clock to be driving all the channels.
Another important consideration you have to make, is the channel placements. As you need max 20G, you will need to use the GXT channels.
Hope this helps.
- Ash_R_Intel26 days ago
Yes, you understood it right.
As 20G can be achieved only by GXT channels and for the clocking at that speed ATX pll is the preferred choice. Refer section 3.1 PLLs of the same document.
- dncmrc120 days ago
It looks like bonding is not supported at rates > 17.4G:
Also the ATX PLL refuses to configure for 20G with bonding:
Can you please help?
- CheepinC_altera12 days ago
Thank you for filing this case and sharing the details. I appreciate your patience. Please allow me some time to review the information, and I’ll get back to you as soon as possible.
Thank you for your question. From your description, you are asking about the maximum data rate supported by the Stratix 10 ATX PLL when operating in bonded mode. You are correct — according to AN 778: Intel® Stratix® 10 L‑Tile/H‑Tile Transceiver Usage, channel bonding is not supported for data rates above 17.4 Gbps. We understand this may be inconvenient, and we appreciate your patience.
In parallel, I am consulting with our DisplayPort IP experts to confirm whether the DP IP can support 20 Gbps while using bonded channels. I will update you as soon as I receive a definitive response.
If you do not hear back from me by the end of next week, please feel free to ping me. Thank you.
- CheepinC_altera7 days ago
After consulting with our DisplayPort (DP) IP experts, it appears that our DP is currently not operating in bonded mode for multi‑lane support. You may want to explore our DP IP.
Please let me know if you have any questions or concerns. Thank you.
