SGDMA - TSEMAC - SGDMA Loopback problem. TSEMAC internal loopback.
Hi Nandish Jasani,
I screen through the KDB link. Those TSE IP counter known issue mainly affecting earlier Quartus version before v14.
So, your Quartus version of v16 should be fine.
dlim
I am replying late, busy with another work, I have done signal taping or Debugging TSEMAC. I have attached word file with four images of TSEMAC signal tap.
1) Image1: TSEMAC Signals before Nios-II Application code.
2) Image2: TSEMAC Signals with Nios-II Application code running. It seems that TX-SGDMA is not working. It also shown that there no event occurs in eop and sop.
3) Image4: TSEMAC Signals show event occurs in TXD[3..0] and TX_ENABLE event occurs. But at the same time there is no event occurs in eop and sop. Why TSEMAC sends data as TX SGDMA is not working?
4) Image3: TSEMAC signals shows tx_ready from TSEMAC is deasserted and TSEMAC now stop working.
So from above observation, there is something problem of TXSGDMA. Can you please share any code example of SGDMA-TSEMAC-SGDMA which is proven? So I can check with my code.
Also please share your opinion by seeing attached image, if require letme know if any more information require in signal taping.
Nandish Jasani.
