NJasa
6 years agoSGDMA - TSEMAC - SGDMA Loopback problem. TSEMAC internal loopback.
Hi, I made the program of TSEMAC in internal loopback mode. I use TSEMAC IP in opencore plus. I made the program to transfer frame from Tx_SGDMA to TSEMAC and internal loop back to Rx SGDMA to fram...
NJasa
6 years agoHi,
You correctly summarize TSEMAC Problems. I have Cyclone-IV E device EP4CE55F23I8L and i used Quartus Primer version 16.1.0 SJ Standard Edition. Please let me know if any bug in this software version.
Yes i am doing signal tap for Avalon Rx and Tx activity. I will try to get what type to error i found. Once i received error i will inform you that which type of error it is.
TSE IP itself calculate CRC in my case.
Presently i am trying debug.
Thanks and Regards,
Nandish Jasani.
