yumada
28 days agomipi csi2 tx, upper limit of video width
Hi, I am using Quartus ver 26.1 PRO Edition and investigating the MIPI CSI-2 TX IP on Agilex 5 E. I generated the CSI-2 Example Design and am running a RTL simulation. To change the video width, I m...
yumada
6 days agoHi Wincent,
Thank you for your reply.
I ran simulations for RAW8, RAW12, and RGB888 and obtained the following results. The testbenches for each case are included in the ZIP file I previously attached.
Similar to your results, RAW8 worked correctly even at 9600, but RAW12 failed at 9600.
Is there any way to make RAW12 also pass at 9600? Or is the maximum supported value fixed by the IP specification, with no available workaround?
yumada
Wincent_Altera
17 hours agoHi yumada -san,
Our MIPI design team is currently out of office.
I will keep follow up and get back to you shortly.
Please accept my apology for some delay.
Wincent_Altera
