Jcole
2 years agoGeneric Serial Flash Interface addressing only generating 22 bit addressing for 24 bit flash
New to using some of the Avalon based cores. I generated a 128MB Generic Serial Flash Interface core for my EPCQ128A Flash, the addressing is only Avalon memory is section is 22 bits, but how do I se...
- 2 years ago
128 MBit Flash uses 24-bit-wide byte address. AVMM interface has however 22 DW addresses + 4 byte-enable lines to access the flash. A doubleword access at AVMM is translated by GSFI core to 4 consecutive internal byte accesses.
FvM
2 years agoIn my math, 128 MB is 4 MW of 32 bit, or 2^22 * 32. Needs exactly 22 address lines.
Jcole
2 years agoYour math is correct, but I'm slightly confused. If I'm not mistaken, the difference due to the word sizes of the GSFI being 32 bit as compared to the byte addressing of the flash.
