EdCz
28 days agoI have work-around the placement error, by the use of the "Tile Interface Planner" This has allowed Analysis & Elaboration to complete.
Synthesis however fails with the following errors:
Error(13076): The pin "ftile_eth|u0|eth_f_0|sip_inst|rd_ptr_sync|ml[0].lrm.CLK0[0]" has multiple drivers.
Error(20073): "non-tri-state driver "f7aq1a_auto_tiles|z1577b_x3_y166_n0|x0_x0_u25_2_hdpldadapt_pld_pcs_tx_clk_out1_dcm"" is one of the multiple drivers.
Error(20073): "non-tri-state driver "f7aq1a_auto_tiles|z1577b_x3_y166_n0|x0_x0_u25_2_hdpldadapt_pld_pma_internal_clk1_hioint"" is one of the multiple drivers. This appears to be a Quartus generation error or some IP configuration combination is not supported. What is the next step?
RongY_altera
Contributor
28 days agoHi,
The Quad location should be valid. Please make the clock only for ethernet (or temporary remove PCIe). In the qsf, not use "PRESERVE_UNUSED_XCVR_CHANNEL ON" and set all rx/tx_serial pins explicitly.
Rong
