ethernet_100g_loopback_off
I have made loop_off in the main.tcl script to check without loopback but still it is showing the tx statistics.
Below I am attaching the screenshots of the system console window.
It seems working as the Rx clk and recover clk are both 0Hz, and lock status = 0, though the MAC status looks weird to me either, would suggest to try some debug and see if the loop_off is correctly set or not first.
the process is in the *\hwtest\altera\alt_aeu_40\eth_ultra_phy_inc.tcl :
May edit the puts here to see if it's set or not first.
- Vamsi_212 years ago
I have kept some puts statements in the tcl scripts as you have suggested but for both loopback on and loopback off the rx clk=0 Hz, recover clk=0 Hz, lock status =0 and still it is showing both rx and tx mac stats.Iam sharing the tcl scripts and also I am attaching the screenshot of the system console window for both loopback on and loopback off.
- Yi2 years ago
Weird, Rx clock it not on even when loop is on? Are you able to use toolkit to check the Rx CDR when loopback is on?
I have taken a signal tap file and added recover clk, reconfig clk to it.I set the clock as clk_ref = 644.53125 MHZ
It was showing recover clk=0 and reconfig clk was running fine.
Below iam attaching a screenshot of the signal tap window.
