Hi Brian,
By using SRC you're likely to control the npor. If so, you need to pull npor LOW more than 100ms and only release it when PCIe ref clock is stable.
Rong
Can you read previous posts?
I am not focusing on npor problem
The issue is changing from HRC to SRC introduce stuck or hang on Linux driver load.
Where the HRC case did not have such issue.
- RongY_altera1 month ago
Contributor
Normally you need to follow the PCIe user guide to set hip_hard_reset_hwtcl to 0. I think you have done that and you're able to boot into Linux.
Once confirming PCIe link info correctly in lspci, you can try rescan and reset commands by referencing https://unix.stackexchange.com/questions/73908/how-to-reset-cycle-power-to-a-pcie-device
Rong
- BrianSune_Froum1 month ago
Contributor
Can you read carefully previous posts?
This is referring to the PCIe itself not slot card nor end-point devices.
You are not even able to type any thing as it stuck or hang once the pcie-altera.ko insert.
Contributor
"Once confirming PCIe link info correctly in lspci, you can try rescan and reset commands by referencing https://unix.stackexchange.com/questions/73908/how-to-reset-cycle-power-to-a-pcie-device"
>>These are Linux commands to test your PCIe. No need to load driver.
Rong
