zener's avatar
zener
15 days ago
Agilex5: How to use a GTS refclk to clock the FPGA fabric?
I tried to use the GTS System PLL configured with FABRIC_USE_CASE and ref clock frequency to 156.25MHz, C1 enable and selected 101.768092 MHz from the C1 output frequency menu but this results in the...
  • FvM's avatar
    11 days ago
    posted minimal design doesn't work because it doesn't connect system PLL output to anything, thus the PLL is discarded during synthesis.
    Modified top.sv respectively
        assign {//pad_rled0,
                pad_gled0,
                pad_bled0,
                pad_rled1,
                pad_gled1,
                pad_bled1,
                pad_rled2,
                pad_gled2,
                pad_bled2,
                pad_rled3,
                pad_gled3,
                pad_bled3} = 11'o213; //12'o4213;
          assign pad_dbg_tx = pad_dbg_rx;
    		assign pad_rled0 = clk101p768092;
    		assign clk101p768092_ready = 1'b1;
    Connecting the PLL reveals another error. The fact that you never got to this point suggests that the PLL wasn't implemented in your design, e.g. due to missing connectivity.
    Error(22849): Intel FPGA IP instantiated in the design requires the DEVICE_INITIALIZATION_CLOCK option to be set to either OSC_CLK_1_25MHZ, OSC_CLK_1_100MHZ, or OSC_CLK_1_125MHZ. This assignment is missing in the QSF file.
    Added
    set_global_assignment -name DEVICE_INITIALIZATION_CLOCK OSC_CLK_1_100MHZ
    Get still complains about missing constraints, but design basically compiles now.
    Frank
    P.S.: Don't know, if DEVICE_INITIALIZATION_CLOCK is actually required to run system_pll. GTS PHY itself needs it according to device handbook.
