15 years agordusedw not count in my dcfifo
rdusedw not count in my dcfifo EP3C16F256C8N Quartus II 9.1 sp2 a dcfifo generated by megawizard plugin manager. rdclk: 75MHz wrclk: 40MHz this is a snipping image of a running signal...
15 years agoDon't lose hope, it must something out there. Fifo usually work.
presence of sampling clock does not mean fifo read clock is wired to fifo, simple to rule out. Your trigger may not work if it misses the startup stage when fpga is configured and write clock starts outright then it will fill up your fifo and the count will settle at zero unless you read fast enough. Just thoughts...
