13 years agoQuestions about SGDMA's IN connected to Avalon-ST Dual Clock FIFO.
If SGDMA(Stream to Memory)'s IN is connected to Avalon-ST Dual Clock FIFO's out,the there are SOP,EOP signals built in SGDMA IN port. The SOP,EOP inside SGDMA IN port is INPUT attributes,and the D...
13 years agoThanks Daixiwen.
"If you configure the SGDMA to use the EOP signal (i.e. set the transfer length to 0 bytes) then it will read data coming from the DC_FIFO until it sees the EOP signal asserted." Or else the SGDMA will receive data accroding to the descriptor and ignore the EOP signal?
