13 years agoQuestions about SGDMA's IN connected to Avalon-ST Dual Clock FIFO.
If SGDMA(Stream to Memory)'s IN is connected to Avalon-ST Dual Clock FIFO's out,the there are SOP,EOP signals built in SGDMA IN port. The SOP,EOP inside SGDMA IN port is INPUT attributes,and the D...
13 years agoThe Fifo also has SOP/EOP signals on it's inputs and will transmit them at the same time than the data. The packet size on the output will be the same than the one on the input.
