LH12
6 years agoQuestion on 5SGXMA3K3F40C4 DDR3 IP
We implement DDR3 IP on the device and saw some stability issues between FPGAs of the same type. Some FPGA works fine while some is not working even though the same firmware is being used. Would like...
Rashmi1
6 years agoHI Ling Hong,
I had sent you an email providing the stage 1 for debug steps. Did you get a chance to go over and see if all those parameters are correct ?
I will further debug the reason for init variation .
Rashmi
