Question on 5SGXMA3K3F40C4 DDR3 IP
Hello Ling Hong,
What performance issues are you noticing ,can you please elaborate on that?
Rashmi
- YTLim6 years ago
Hi Rasmi,
Allow me to elaborate.
In our H/W architecture, we have 2 physical DDR3 modules connected to the FPGA. We implemented the DDR3 IP on the above mentioned FPGA successfully. However we did see some FPGA to FPGA stability issues.
A particular firmware may work on some FPGAs but may fail on another FPGA of the same type. While another firmware with slight tweaks may work on all the FPGA.
Some other very minor firmware tweaks, even if we did not touch the DDR IP, may cause both DDR3 modules to fail on all FPGAs.
One of the key indicator that we look for in the implementation is the ddr_init signal. On some FPGA, we can see a successful init while on some other, the init was unsuccessful. It could happen to one or the other DDR module or both modules.
If both DDR modules are able to be initialized, the whole system will run fine.
Let me know if you require more information.
