17 years agoQuestion about FIR filter outputs
Hi, I designed FIR filter and I try to undestand why the number of output samples is different from the input? It lacks 2-3 samples. Thank you for your help.
17 years agoA couple of them probably got stuck in the Avalon ST FIFO. I ran into that problem a couple versions ago (haven't checked the latest version yet, so can't be sure). If it's really a big deal for you, just zero pad your original input a little bit.
