17 years agoQuestion about FIR filter outputs
Hi, I designed FIR filter and I try to undestand why the number of output samples is different from the input? It lacks 2-3 samples. Thank you for your help.
17 years agoHow do you do the counting? hopefully not by fingers...
Every filter output needs initial time to settle. the internal delay line(same as number of taps) have to be filled up first. The output will only be correct after this delay line is full. just in case, groupdelay of FIR is order/2 and is a different concept.
