17 years agoQuestion about DLL
Hi, I instantiated a DDR2 core with DDR2 SDRAM Controller v8.0, and enabled the "Memory device DLL enable". The generated DDR2 core has the input port named dqs_delay_ctrl[5..0] and output po...
17 years agoThe "Memory device DLL enable" signal has nothing to do with those ports. That checkbox is to instruct the controller the enable the DLL on the SDRAM chip itself.
The fact that you have those dqs_delay_ctrl ports indicates that you also checked the "Instantiate DLL externally" checkbox in the core. You should only do this if you want manual control over the DQS delay. Edit your core and uncheck the "Instantiate DLL externally" checkbox. Jake
