13 years agoQuartus-II FIR compiler-II DSP IP Core
Dear friends ,
I am a beginner in Quartus -II tool . I generated an IP core for band pass filter of order 64 from DSP->Filter-> FIR compiler II in Megawizard tool box . The default outputs are simulated in Questasim . When I simulated with my inputs(no. of i/ps :250) ,the output should be 250 as from MATLAB . But in the IP core I'm getting only 245 outputs with first 32 values as delay ... Any solution ...??1 Reply
--- Quote Start --- Dear friends , I am a beginner in Quartus -II tool . I generated an IP core for band pass filter of order 64 from DSP->Filter-> FIR compiler II in Megawizard tool box . The default outputs are simulated in Questasim . When I simulated with my inputs(no. of i/ps :250) ,the output should be 250 as from MATLAB . But in the IP core I'm getting only 245 outputs with first 32 values as delay ... Any solution ...?? --- Quote End --- I assume you mean you apply impulse input of value 250 and matlab says your max output should be 250 after initial values. i.e. you are targetting unity gain. The difference of 245 from 250 most likely indicates rounding issues with your coefficients. I don't know about your tool but is likely you have chosen a rounding method different from that of matlab.
