RicardoC
2 years agoQuartus 24.2 CXL ED support for DK-DEV-AGI027-RA
The R-TIle Intel FPGA IP for Compute Express Link (CXL) Example Design in Quartus 24.2 does not provide an option for DK-DEV-AGI027-RA as a development board.
How can the ED be generated for this board?
Thank you,
Ricardo
- WZ2
Hi there,
Yes, they only support DK-DEV-AGI027RBES and DK-DEV-AGI027R1BES now. I recommend u use AGI027RBES to generate the ed and change the device after the generation, due to they use the same power solution and configuration details.
WZ
- RicardoC
Hi WZ,
Thank you for your feedback.
Does it mean that the PCBs DK-DEV-AGI027RBES and DK-DEV-AGI027-RA are identical to each other, and the revision of the FPGA is the only difference between them?
Thank you,
Ricardo
- WZ2
Hi there,
Yeah, that is right~
WZ
- RicardoC
Thank you, WZ.
