11 years agoQuartus 15 ALTLVDS_RX MegaWizard Errors
I'm trying to create IP ALTLVDS_RX for project with Cyclone V. But with defaults parameters MegaWizard says Error: Parameter VALID_PHASE_INCLOCK has been assigned the value 0.00 which is incom...
11 years ago --- Quote Start --- I have create new project, select 5CSEBA2U23C8, then start ALTLVDS_RX wizard and I got the same errors. The "Currently selected device family" ComboBox is empty. I've try Cyclone IV and Cyclone IV GX, and got the same result. --- Quote End --- Probably you should file a service request to Altera on this since you have done quite some debugging. If you have a Windows OS, test with Windows Quartus also.
