11 years agoQuartus 15 ALTLVDS_RX MegaWizard Errors
I'm trying to create IP ALTLVDS_RX for project with Cyclone V. But with defaults parameters MegaWizard says Error: Parameter VALID_PHASE_INCLOCK has been assigned the value 0.00 which is incom...
11 years agoYou would need to specify the device family as there might be different set of internal parameters for different device families. If you select Cyclone V + "use external PLL", is the error still exist?
