17 years agoQuad Video Mosaic example from Bitec
Hi there! I've been fiddling around with the Quad Video Mosaic (http://www.bitec.ltd.uk/hsmc_qvideo_mosaic_ref_design_vdk.pdf) example and comparing the latency of the video to the VIP Example Desig...
15 years agoHi ,
I am not sure but you can find some code from Altera for the DVI and also Quad Video settings in the location you installed the Altera tool.I give you the path of the files.Here there is code of CVI and CVO components. C:\altera\10.0sp1\ip\altera\clocked_video_input\src_hdl Check it .May help
