10 years agoQsys:Peripherals:Frequency_counter
There is a "Frequecy_Counter" IP in SOPC and Qsys, but there don't seem to be any instructions on how to use it. When I click on the "Datasheet" link for the IP, it brings me to the "ub_embedded_ip....
10 years agoDoesn't exist in Quartus Prime, and no mention in the revision history of the Embedded Peripherals User Guide. But I also have Quartus II 13.0 installed and it was in the Qsys library exactly where you said it would be.
I get that IP cores come and go, but there should at least be a record somewhere and access to older versions of the documentation in case you're using older tools as you are. There is absolutely no mention of that core anywhere on the Altera web site that I can find, which is pretty incredible really. Nothing in the knowledge base, nothing on this forum. Like it never existed. I would open a SR with Altera just to get an old copy of the Embedded Peripherals User Guide, and to find out in what versions of Quartus it existed. Altera's documentation management is pitiful. If you're running Quartus v13.0 (or any other version) and instantiate a component in Qsys, the documentation link should take you to v13.0 of the document, not v16.0 where the component no longer exists.
