10 years agoQsys:Peripherals:Frequency_counter
There is a "Frequecy_Counter" IP in SOPC and Qsys, but there don't seem to be any instructions on how to use it. When I click on the "Datasheet" link for the IP, it brings me to the "ub_embedded_ip....
10 years agoFound it at Qsys : Library : Peripherals : Debug and Performance : Frequency_counter"
The main source file starts with this:// (C) 2001-2014 Altera Corporation. All rights reserved.
// Your use of Altera Corporation's design tools, logic functions and other
// software and tools, and its AMPP partner logic functions, and any output
// files any of the foregoing (including device programming or simulation
// files), and any associated documentation or information are expressly subject
// to the terms and conditions of the Altera Program License Subscription
// Agreement, Altera MegaCore Function License Agreement, or other applicable
// license agreement, including, without limitation, that your use is for the
// sole purpose of programming logic devices manufactured by Altera and sold by
// Altera or its authorized distributors. Please refer to the applicable
// agreement for further details.
//Frequency checker
//Author: Harold Wang
`timescale 1ns/1ns
module frequency_counter# (
parameter CROSS_CLK_SYNC_DEPTH = 2,
parameter REG_WIDTH = 32,
parameter DEFAULT_MAX_CNT = 1000
input reset,
input avs_clk,
input avs_address,
input avs_write,
input avs_read,
input avs_byteenable,
input avs_writedata,
output reg avs_readdata,
input ref_clk,
input des_clk
//Local parameters
etc. If it's in the menu, and the code has the Altera copyright, then it sure wasn't written by me! And, no, I didn't find it on Google or on the Altera site either. That's sort of the point. It is in the main IP library (at least on my machine, and i did not put it there, and I'm the only user), but there is zero info anywhere about using it. Looks good on paper, but reality is a completely different issue.
