14 years agoQsys won't generate testbench with VHDL 'application' source...
As described here.... http://www.alteraforum.com/forum/showthread.php?t=31416 .. I have a system that I'm trying to get working with the CycloneIV hard PCIe interface. This is a syste...
14 years ago --- Quote Start --- The only solution is to generate the simulation in verilog (so if you've some custom components in qsys written in vhdl, you've to translate it in verilog for the simulation porpouse). --- Quote End --- It can not be the case that if we prefer to write VHDL code, that we have to manually code the same functionality in verilog, just to be able to simulate a Qsys system?
