10 years agoQSYS SPI not parametrized ?
Hello, I am trying to test my own SPI (master) BFM so I used QSYS o create a simple design: SPI_BRIDGE and one ONCHP RAM. My question is: How can I find out the parameter of the SPI_BRIDGE ...
10 years ago --- Quote Start --- I don't have any answers for you, as I ran into some similar questions/uncertainties with some of the SPI stuff. When it came to implementing a slave device, I ended up using the spi slave to avalon MM master found on the alterawiki site. I customized it for word/address size and simulated it so I understood how it worked. It seemed like a better starting point for me since there was some documentation. There must be a better way to use the altera SPI stuff but it wasn't obvious to me. Hopefully you will get a more helpful response as I would like to know more as well. Lance --- Quote End --- Hi Lance, I sort of cleared the mystery a bit when found the spec. for the spi_bridge_MM. The spec's link is broken... but if you google it you see how screwy it is to use. Anyway, I used a external-master-bridge with an external slave SPI, instead. Cheers, S.
