14 years agoQsys PCIe core fails timing
Hi, I've been analyzing the Altera PCIe Hard-IP cores. I started off with the Qsys PCIe code, since it had the simplest interface. Here's the test setup: * Quartus 11.0, 11.1sp1, 11.1...
12 years agoOk Dave ..
Yes I am going to run Simulation, but it is difficult to get the NIOS II stimulation ... since as I understand that , it is just a BFM master .. I am thinking that if I can demonstrate using Eclipse, just one NIOS II instrunction being executed under the debugger will cause the conditions to fail, then I may have information that the JTAG debug port is doing something ie enabling the NIOS II data / instruction masters. On SignalTap, that will yield more exact information... I will be able to then say the problem is on the PCIe Hard IP side or on the Avalon MM interconnect fabric. I am currently constraining the PCIe BAR Avalon MM master to be "single DW completer" to see if that will constrain things to issue a single write / read at a time. I am still not sure how to run SignalTap and Eclipse at the same time since Eclipse is using the JTAG / USB port that SignalTap would use. It seems like I would need to commit the NIOS II SW + bootloader to Flash so Quartus would be in control of the JTAG Ok on PowerP ... I was in PowerPC land for some time.
